Greetings. Symptom: pressing the front windshield washer button does nothing. No wiper activity, no spray. However, on regular wipe functions, the wipers work fine. Also, the rear wiper and washer work fine. Any ideas?
Thx,
J
Thx,
J
The pump is definitely not running. I can check with a voltmeter to see if it's getting power. Can you offer some guidance as to it's location?rrtoadhall said:Have you checked your washer pump?
Thanks for the tip, but no such luck. Guess it's just time to break out the old volt-meter and trace the circuits. I've ordered an shop manual; it's about time I had one. Hopefully that will help in diagnosing the problem, or at least locating the various components involved.medcapequip said:I remember in my old Audi if the washer fluid level was not high enough it would not work. Is your tank full?
Yes, it did, which is why it's a distinct possibility (probability) that the BECM is just wacked in that region. Hence why I'm asking if anyone knows of a resource with more info on the BECM relays and transistors, and which ones control which functions so we might have a shot at fixing it without replacing the BECM.rhino_ed said:Didn't your becm take a swim a little while ago? Did you look at RAVE?
