Gents,
Couple of questions; I've got a '97 HSE, in the HVAC there's a button what says windscreen prog, when I press it the rear screen demister goes on and the blowers for the windscreen go on.
Can I actually program this? It says "prog".. If yes; How?
Or is it just to demist the windscreen at full blast?
When I put the car in reverse the mirrors adjust automaticly, can that be turned off? I think it's annoying, had a look with the nanocom, couldn't find anything.
1995-2002 Range Rover Classic
no you cannot adjust the hevac programming, yes you can turn off the reverse mirror adjust. if i remember correctly with key on in second position you open drivers door, then press and hold memory switch until the cluster display shows mirror dip off.
