2013-2015 Range Rover Sport
Hi all, im new here and my recent purchase is my very first RR.
Ive been chuffed with my RR to date, however been on a long run over the past 2 days and returned frustrated.
For some reason all of my windows mist up regardless of the setting I use on the climate controls.
I then tried my A/C on low to see if that's working and it only blew warm air, not cold at all.
when I put the rear heated window on, the rear side windows (in the boot area) don't demist at all either
Any ideas what's going wrong?
2019-2021 Range Rover Sport
You need to tell us what year make and model or we cannot help you. Add all this info to your signature as well as your location.
Without knowing those details and the temp/weather outside i can only advise you if you have recirculate on this could cause fogging of the windows.
Also. Are the rear quarter windows heated or are those grid lines for something else? As they don't appear to work with the rear heated window?
