My 4 day old 2006 RR HSE has a terrible wind noise on the passenger side window at highway speed. The dealer is going to pick it up this week and have a look, but before then I wanted to know if anyone has already experienced and fixed the problem. It sounds like it is the rubber seal on the outside of the door not making contact with the inside rubber seal. I noticed that there is a rubber strip that runs up the outside front edge of the door (just behind the "A"pillar black trim). The passenger side piece seems to be not as flush with the pillar as the driver's side. Perhaps the wind is getting under this piece and causing the noise? It sound like the window is not closed at 100+ kmph. Any insight would be appreciated. :?
Discussion Starter #2
The dealer re-aligned the passenger door and now the wind noise is gone. :D
