I need an additional power supply connected to my battery so I can run diagnostic tests with the Alltel scanner,
A note says that the power must remain at 12.50 v or higher or the scanner testing will not work.
Instead of using a battery charger will this unit work
I use a JLR approved Midtronics PSC-550 power maintainer for software flashing and to run the system during diagnostics.
It gives it 13.4v but 55 amps output to support the entire systems. It consumes 950w to make that output.
Frankly what you're posting is a 12v accessory power supply with a 5 amp output and wouldn't be powerful enough. That's designed to power cell phones and small accessories.
281576
