1 - 9 of 9 Posts
I tried to purchase a cable to plug into my comp/eas from one of our sponsors, but he is currently back ordered and suggested I search elsewhere.
So I came across this cable, Will it work the same?
OBD2 16Pin to DB9 Serial Port RS232 OBDII Adapter Cable
Connect your diagnostic interface and your vehicle with this OBD II to RS232 connector cable.
OBD II 16 Pin Connector
RS232 Connector
Battery Power 16
9
Chassis Ground 4 1 + 2
Signal Ground 5
1 + 2
CAN High J-2284 6
3
CAN Low J-2284 14
5
ISO 9141-2 K Line 7 4
ISO 9141-2 L Line 15
8
J2850 BUS- 10 6
J2850 BUS+ 2 7
So wll I be able to use it to access my EAS computer Via the program offered by one of our sponsors?
Nope...
I just made and sent one of these cables out to a buddy for use with the RSW software. You need to get an open ended OBD2 J1962M cable and custom solder/crimp a DB9F connector to its end, in accordance with RSW's instructions. There's no commercially available substitute cable. Leave it to LR to communicate in a non-industry standard configuration.
Get the OBD2 open ended cable here:
http://www.obd2cables.com/products/obd- ... -open-end/
and go to Radio Shack for the DB9F connector.
Use instructions from RSW and cable supplier to match open ended wiring colors to correct DB9 pin configuration.
Either will work, but for the sake of a few bucks you're chaining yourself to a much shorter lead.
There's no way to tell for sure that it will work. As you can see from the ad, the cable provides limited pin comms. Does it have all 16 pin wires from the OBD2 plug contacts in the cable, or did the original mfg only spec the wires necessary for the configuration? If the latter, then you might cut open the cable only to find a limited number of hard moulded wires. Basically useless. :( ...or you could score yourself a bargain.
Not sure if you guys have Mouser in Canada, but if you do, they carry all the parts you'll need. If you make them from scratch, if my memory serves me correct, it was like $2-3 total for the OBD and serial connectors and another $1 for the OBD pins. The cable, I bought at local hardware store for about $2.
1 - 9 of 9 Posts
