They will fit, stock tire size is 255/55/19 so these are a little narrower than stock and slightly taller in overall diameter 788 mm vs 763 mm. They will turn 650 revs per mile vs 671 for the stock tires making your speedometer read about 4% low. Those are probably RRS wheels as the 2018/19 sports have a stock wheel with those size tires. its a 19 by 7.5" wheel with 5 by 120 lug spacing with a 44 mm offset. Stock wheels are 19 by 8" with 5 by 120 lug spacing with a 57mm offset. The new wheels will sit a little deeper into your wheel well (13mm) so if you ever upgrade the tires you need to watch the space between the back edge of the tire and the suspension if you get up near 255/55 tires, but even those should clear due to the wheel being 1/2" narrower.
