Hey guys, I’m installing a Switch-Pro 9100 in my 07’ RR 4.4L for my off-road lights and want to mount it where my clock is below the climate controls seeing as i never actually use it. Does anyone know if it’ll cause a fault (check engine light) if I remove it?
I have a wiring diagram for post-263535 VIN's which shows that there are four connections to the analog clock: +ve, -ve, illumination and I-bus.
The correct time clock setting is probably adjusted remotely through the I-bus.
The clock's I-bus connector is a terminator rather than a looped connection so chances are fair that a disconnected clock may not throw an active fault code but you may well see a fault logged in the body control data if you pull a list of stored codes at some point in the future.
I guess you're the guinea pig here ;) so you'll have to let us know :).
Rob
The answer would be negative, removing the clock does NOT throw a fault....
What tablet mount is that?
It’s a RAM Mount. It’s bolted the seat rail on the passenger side. It’s an aluminum pole that you can bend to fit. I’ve got it bent so it’s pressed against the side of the center console Sonora doesn’t shake. It fits perfectly!
