1 - 17 of 17 Posts
· RIP Our Friend
Last night I was in process or layout the PCRC magazine when I came across these pics from an Australian trail run. After I felt like crying for whoever Ralph is, even though he is smiling, I began to wonder if he were a member here. The run was put on by the Sydney Land Rover Owners Club for NW visitors Pamela and Paul Petroff.
· LEGACY VENDOR
Carl what mag are you talking about. PCRC ?
Scotty
· Premium Member
I thought our doors were designed to not let any water in up to the character line?
Maybe bad seals, or he didn't climb out of the window to strap up, but instead opened the door.
PS...I've been there in my Jeeps, and never again will I go into water that deep for fun. Even when you make it out you eff up a ton of other crap...and if your diff vent tubes weren't run up high you have to change the fluid every **** time you do it. Screw that noise.
I also thought the seals on our oil pan and valve covers are not supposed to leak either :lol: .
hi rrtoadhall ,hope this answers your questions/yes i am a member(as of today).and no didnt destroy my p38a ,our members from LROC sydney pulled out my computor ,cleaned it and put it back under seat and then restarted it first go .if you want to see more pics go to photobucket site ,type p38a in search box and look at my rofosixone pics ,enjoy ralph .
ps nissan who went through same waterbog ,his diesel motor died /hope this answers the above questions ,cheers.
Impressive but it does make me wonder:
If on air springs then you could have hit a button on the dash and had another two inches clearance to get through.
If you still got stuck then the system ill go into extended mode to try and get you out.
If you were still stuck then the car would have been significantly higher and very probably the BeCM would have been high and dry anyway.
Why do people think coils are so much better if off roading????
· LEGACY VENDOR
I'm pro airsprings but in that case i'm pretty sure that when the BECM get wet, he'll got an hard fault and bumpstops to increase damage.
I really need to make a EAS disable switch for that kind of situation.
· RIP Our Friend
Discussion Starter · #15 ·
paul.adshead said:
Pull the EAS power relay - takes ~3 seconds.
That is exactly why my relax has been removed from its metal clip and is held with velcor at the front edge of the seat trim. I can reach down and give it a quick pull without getting out of the seat, opening the door, playing around with seat trim etc.
· LEGACY VENDOR
Same thing here but that doesn't look to do the relay trick in front of friends, that looks defender, not range rover `)
1 - 17 of 17 Posts
