I have a problem, my newly re-built engine is running lumpy and the "Check engine" light has come on saying it has detected a misfire. I have pulled all the leads off with the engine running, to confirm each plug is working which they were. this leaves the dizzy, or the injectors. As the dizzy has done 176,000 miles I though I would change this first, I would have liked to get Mallory dizzy but at £450 it's not an option! I spoke to a Distributor expert and he said try and get a English made Lucas as alot of the new dizzy's are made in china!
So does anyone know where best to get an original English built Dizzy from, or a dizzy that is solid and reliable?
Jonny
I could also be a weak ignition coil. They're a lot cheaper than a dizzy, and if yours is original it might be time to replace anyway.
I tend to replace the cheaper things first, hoping I hit the culprit :dance:
