1 - 1 of 1 Posts
There isn't one.
It is a decent procedure to check fluid level, trans fluid needs to be cool, engine running vehicle in P, and pull the fill plug on the RH rear of the transmission, above the pan, behind the shift cable. Monitor fluid that comes out, top off if needed until small stream flows out, and reinstall fill plug before fluid temp rises above 50* C.
1 - 1 of 1 Posts
