Looks within tolerance to me! ;-)
Not dumb at all. If I had thought to pull the front cover apart I would have found this alot sooner. :mrgreen: You are dead right though, there should be three gears. Instead I have two gears and 15 little nubs that used to be the outside gear.BargePilot said:'What is wrong in this picture?' Took me some time to get it, but I am dumb.
This is what it sould look like, I believe.
(Image stolen from ebay. Apart from being dumb I'm shameless too)
I notice that my front cover already has the updated front seal installed. I can only guess that the front cover was pulled to install it and they nicked or fouled the oil pump gears when reinstalling. I can easily picture that a crack would lead to a chain reaction busting of the outter gear.Scotty said:Carl, what do think caused the failure?
Has the outer gear breaking up not caused damage to the housing? I would check carefully that the gears are free to turn when the plate is fitted and torqued up.rrtoadhall said:So after a quick shot of orange cleaner, and installing the new gears, here is what it should look like when you pull the pump cover off.
I had two very tiny nics in the aluminum front cover and one in the pump cover. No gouging or scoring is present. I can press the outter rotor into place with very little effort. I was just wasn't sure if it was really supposed to be firm or was to spin. Thanks for the confirmation of what came to me at 3:00 this morning. :? It's amazing how walking away from a project will clear things up.nipper said:Has the outer gear breaking up not caused damage to the housing? I would check carefully that the gears are free to turn when the plate is fitted and torqued up.rrtoadhall said:So after a quick shot of orange cleaner, and installing the new gears, here is what it should look like when you pull the pump cover off.
