Whats the proper torque for our wheels? Rinspeeds are coming off and the stormers are going back on -
also, anyone know off hand the proper lug/bolt size, I may need to get the attachment ..
Torque for original rims and lug nuts should be 140Nm (+-10), or about 103 Lb-Ft. OEM lug nuts are 22 mm, not sure what you mean by attachment, are you talking about the socket for your torque wrench? If so get the deepest 22mm socket you can find (or an extension), it's easy to scratch the wheels otherwise.
22 dents the lugs caps. 23mm works alittle better. Deep. Spin with an impact till it stops, then finish with a torque wrench. I have a ridged that stops the impact after 1 rotation.
