1 - 11 of 11 Posts
Can any wise board members give me some clarification as to whether 2010 RR Supercharged wheels will fit an '04 RR HSE ?
I've read that all you need to do is upgrade the lug nuts, but I've gotten every answer possible from a variety of dealerships here in Canada. From outright "no way" to "not a problem"....
Would appreciate the help.
Stevemfr said:
I guess kmagnuss has not yet moved from the P38 to the MKIII or you'd be reading a... shall we say, rather direct note about using the search function. :p
Checking the main site is very useful too - and good reading:
http://www.rangerovers.net/outfitting/t ... tires.html
the paragraph under all the wheel pics
I would like to know if the '10 wheels will fit a pre-'10 as I have called several dealers and they have said they will not. They say they do not know why and can't tell me a single technical spec of a '10 wheel. Offset, bolt patern, nothing.
I used search and the link above didn't help.
· LIFETIME CONTRIBUTOR
I would expect the 2010 wheels to have the diameter and offset embossed on the rim - probably on the inside (the hub mounting side) like my older RRS rims I have on my P38A.
The P38A. D2, L322 and (at least early) RRS have an offset of 57mm and a PCD of 120mm.
Freaking great to hear. I'm going to order now!
Thanks so much. Your photos look great! I can't wait to get mine. I hope the the "back order" black hole doens't last long.
L405 RR Classic
The only wheels I REALLY want are the Overfinch 22's but they look a little to big :( If they made then=m in 20's I would be all over them. My 05 came with a like new set of 07 RRS wheels and like new tires. Hate them. I would trade them for stock 03-05 wheels in a heart beat.
1 - 11 of 11 Posts
