Found loose in engine bay rear right compartment - where the brake reservoir and distribution manifold is:
Discussion Starter · #2 ·
Well - it's Item 9, Cover Battery Box. I guess it doesn't fit anymore because I don't have the original factory battery.
It is item #9, but does not cover the battery, it goes on the opposite side, you will see the cut out in the fire wall and holds the hood wires and hoses will clip to item #9. I purchased a 2010 SC Range Rover used and the car lot remove all the battery hold down hardware. I purchased all the parts and have a extra item #9. Not sure why this part in battery. It just snaps in.
Thanks! I'll check it out - I was wondering because I couldn't fathom how it could possibly fit over the battery. So it goes in the brake manifold compartment on the (US) driver's side?
