I was told today by three different vendors that the steel brake lines are no longer available for P38. What size steel line and fittings do I need for P38? Any sources in the US would be appreciated. I know where to get the tools for bending and making flares, but I need the actual raw material (galvanized steel tubing and fittings). Thanks.
1995-2002 Range Rover Classic
fittings, you can cut you lines and reuse the fittings, otherwise find thread pitch and order from ebay, steel brake line is normally 3/16. english cars use bubble flare, it can me made with regular flaring tool but if doing more than a couple this is much easier
classictube.com/product/universal-hydraulic-flaring-tool-kit/ make sure it has the die kit for the bubble flare.
