What size allen head for the front differential fill plug on a 06 RR?
Thanks. I suppose the drain plug is the same size?
Re: What size allen head for the front differential fill plug on a 06 RR?
14mm autozone sells a 3 pack of allens 14, 17, 19 ,for about 12.00
Awesome. Thank you.
i tried to do this and could not fit a tool in there i had to suck the fluid out with a pump instead
Huh? Were you simply not using the right wrench? DId you not clean the plug first?
First you remove the fill plug to make sure you have a way to fill. Then you remove the drain plug. Wrap drain plug in tef tape and install. Fill and install fill plug. Diff oil changes are easier than than motor oil changes.
i changed the rear dif and the transfer case but could not get to the drain plug for the front dif out i could not fit a tool in there :( to small of a space
any ideas? maybe its a 2006 issue. i did find the right size driver but could not get it in there to take it out
thanks`)
Banned
did you remove the "engine protection" (semi skid plate) under the front diff?
