Thanks for the info. My copy of "RAVR" is corrupted unfortunately. What is..."eas sid"... that you refer to please?the bags vary based on height, as low as 30 psi to as much as 70 psi depending on load weight, level height, terrain, etc. I used a gauge on my system temporarily and it drove me bananas at the extreme changes from one street block to the next.the storage tank is capable of 150 to 180 psi at 4 gallons. other than the bag pressures, all the info is on the rave and eas sid.
I TRIED to amend my spelling mistook!?!?!, but as I noticed it more than 15mins after I had made the post, the "system" wouldn't allow me to. Can't download a replacement copy of RavE currently, as I am restricted by my mobile - Cellphone for the benefit of our North American friends - data plan. Thanks for the advice.no clue what RAVR is... but if you really mean RAVE, just download it again...
Thanks for the info!10 bars top pressure for high mode , 8 bars normal. Enviado desde mi SM-A720F mediante Tapatalk
Thanks for that...I have used the search facility several times, but despite receiving different responses to my search request, I've not come up with the docs. I'll try searching again using; Electronic Air Suspension, System Information DocumentS Many thanks, MikeElectronic Air Suspension, System Information DocumentS… eas sids.
Many thanks for your input, Richard! Mike.The pressure is irrelevant, it's the volume of air and the weight it is trying to support. If the car weighs 2 tonnes and the weight is evenly distributed, that's 500kg per corner. So the pressure will be whatever it needs to be to raise the car to normal height. Load the boot so the rear bags are supporting 750 kgs each and the pressure will go up to lift the car to the same height. The system stores air at a pressure of around 150psi which is greater than the pressure needed to lift the car under all circumstances so the working pressure will be lower.
Dave, thanks for your input! Mike.The compressor cuts off at around 12 bars. The car will start to lift at around 6 bars.
