Hi all, when I bought my new to me Range Rover, the window trim piece was scratched/damaged and it's really bothering me. What is it called? I can't figure it out, id like to replace it. Thanks.
I think that is part of the door frame that is not replaceable...it is masked off and painted at the factory...
Its called a seal part number is LR021647 (North America driver side front on an 06 HSE should fit an 03 thru 12 though). Theres also a U shaped Channel that fits behind it and holds the glass in That part is DDC0DDC000145PMD for the right side 00155PMD for the left side . Shouldn't need that part though, just the first one. About a hundred bucks from the dealer.
Thank you so much! Will give the dealer/my Indy shop a call this week. Searched through RAVE for hours and couldn't find it, thank you again.
So just to be clear, this part # is the solid matte black trim piece, not the rubber gasket, correct?
Did that, but it seems to be showing the rubber gasket piece, so I'm unsure.
Yeah, that's what I get with google too. part number should have been LR021648 for the left side but it still looks like the rubber upper gasket on the inside of the door.
