Hi!
I'm going to be swapping the motor in a 2006 supercharge jag engine.
While the engine is out, there are some obvious things I would like to do such as:
Change valve cover gaskets
Change timing chains
Change rear oil seal
Change plugs
Change oil pan gasket
Change supercharger gaskets
Replace serpentine belts
Is there anything else I am missing that should be done while the engine is out?
Also.... Would this be a good time to flush the heater core and radiator or does that really matter?
Thanks!
Change plugs
Thanks!
