I have a vague idea of what the Becm does and am worried mine is fried, but just wanted to check on everything it does as it seems expensive and tricky to replace.
Does it control the message centre? (this works fine)
Does the EAS go through it? (I have an EAS unlock cable and expected it to work without the engine running but it doesn't)
All the Electrics such as the Windows, Sunroof, RCL ect all work fine are these through the Becm?
My main fault is that the Becm isn't activating the relay to activate the Starter Motor, but the EAS not responding concerned me too.
Is there a fuse or something I have overlooked which may just need reconnecting to get it all to work?!
Am I correct that when the becm loses synch with the ecu that the engine still cranks but won't fire?
Am I also correct that the Gems motor doesn't suffer from the lost synch?
