Hi. My P38 has started to sporadically display RANGE in the display panel. Does anybody know what this means? I can find no info.....
It should display range when you cycle thru the modes with the left bottom switch, it is how far you can go on gas.
Range is Low range or high range. it means using your H gate to access Low range an seeing what is up and if it is working.
Super Moderator
High or Low Range is shown by an L and the gear you have selected such as L 3m or just the gear if in High range. RANGE with a number displayed is, as said, the range you have left before the fuel tank is empty.
