Yesterday I decided it was time to investigate the distribution/blend servo issues as it was blowing cold air to drivers side mild to the passenger and all going to the front windscreen.
So after Reading the stickie I went for the distribution servo first as it sounded the easiest to get at.
So removing the trim I watched the White plastic gears (as shown in the photos) to see how much movement was noticeable and very little was the outcome. So while switching the ignition to see the servo go through it's auto check I used a long flat blade screwdriver to add a little extra push pull to the gear and it worked it moved passed the point at which it was stalling and continued to move through it's full range of movement.
But not wanting to give up at this stage I just used a broad flat bladed screw driver to separate the distribution box then I inserted the plastic tube from a can of silicone spray and a few squirts later the unit was running like new.
The next problem was the blend motor drivers side as it was bloody freezing.
After Reading the info on these my thoughts where leaning towards another stuck flap rather than a unit that had stripped teeth as I would expect to hear a motor running but nothing moving if this was the case and all was quiet.
So using a spare wooden hammer shaft I rested it on the top of the blend servo and with the handle of the large I screwdriver I give it a few taps and it sprang back into life distrbuting lovely hot air to the drivers side I still can't belive my luck but for those with servo issues it has got to be worth a bit of spray and a few taps of the motors just in the case they are stuck.
