I typically use Mobil 1 for my 911 yet upon checking on Mobil website, it indicates they don’t have any product for supercharged V8..any recommendations ?
A high quality 5w-20 is fine from any good brand ie Mobil 1, Pennzoil, or Castrol.
I’ve been using Pennzoil Platinum Plus 5w20 in two 3.0 Supercharged engines with great success.
Sent from my iPhone 7 Plus using Tapatalk Pro
SUPER MODERATOR
2010-2012 Range Rover Sport
Oem is Castrol professional 0w/20. I would choose Castrol edge extended performance 0/20. They have almost the same specs.
id stick with what the manual says to use. i could only get it at the dealer
SUPER MODERATOR
I used Castrol professional from my dealer, but after one oil sample from blackstone showed some contaminants of sodium. Hence, I chose a bottled Castrol from Walmart. An OA later showed perfect wear and protection of this oil.
My dealer has a tank with tubes etc attached to it, which looked gross! I wanted to bring the oil to them to fill. I’ll find Castrol professional or edge 0w/20 and provide to them. I’ll look for the qty but would appreciate if you guys let me know...thanks
