I lately changed the pollen filters, plenum filter and cleaned the sunroof drains. The o rings are also changed since they were leaking already when I bought the car.At least the spare wheel space is clean and dry so far. After some rainy days I discovered that the both front footwell carpets are wet on the part that is close to the door- outside part.
First i was thinking that maybe there i rust issue somewhere behind the front wheel but when I found out that both sides little bit wet, i believe it must be something else. Where to start?
