199 RR 4.6HSE
I have read MANY posts and hoped someone might have a suggestion. I have not had any luck with the locals whom have T4’s and Autologics. In my vehicle, every single light on the instrument cluster illuminates when the battery cable is connected. The gauges do not work and the display only shows a few vertical lines. This happens with the key in the ignition, out of the ignition, vehicle running, not running, ignition on or off. The vehicle operates normally in every other aspect. Everything works. The BECM and the Cluster have been replaced with no change in condition. I have not found any wiring damage. The ignition switch is not the problem.
Do you have any ideas? I have been trying to figure it out for over a year now. I have the whole interior pulled out, even the dash.
Any ideas will be greatly appreciated!
Thank you,
Raphael Puzio
Thank you,
Raphael Puzio
