having trouble with starting AGAIN, flashes up all kinds of faults on dash, checked fuses under bonnet for live feed and fuses 23 srs and 24 abs both seem to be earths somehow, any ideas on whats happened please? thanks
2017 Sport SC Dynamic
lift the relay in the lower left hand corner of the fusebox under the hood...if the plastic is cracked where the relay pins go in, you need a new fusebox panel. I have one if you need it, depending on what your model # is. it will say on the fusebox lid which petrol model # you need.
