All,My 2006 RRS has never failed to start (touch wood), but the duration of cranking before it starts seems to vary between almost straight away and 3-4 seconds and I can't determine any specific cause. Once started the car runs absolutely fine.... I don't believe it is fuel related, as I've let the fuel pump charge up from anywhere between 1 and 5 seconds. It's not heat related as I see this on both cold and hot starts. I'm thinking it may be a bad crank position sensor, plugs but I am open to any and all ideas on where to go hunting. BTW I've had AJ8 engines in many different jaguars over the years (2 S-types, an XJ8, an XK8 and an XF SC) and none have ever had a problem firing within .5 seconds of cranking..... The car is an RRS 2006 non-supercharged with ~128k miles. No full history so not sure if plugs a CPS were ever touched.
Mine does this when my battery start getting low and needs to be replaced. I have a 2008 RRS SuperCharged. At least one place to start looking before it gets on the diagnostics.
Battery is <1 year old and tested fine. I have been taking notes over the last week and it seems as if the long crank is more associated with a cold start. I have seen on other AJ8 engines that a short duration hot start can lead to what feels like a flooded condition and a longer crank, but that is not the issue at hand.
Mine always starts the same way, cold or warm. Sounds like at least two rotations. Never starts at the touch of the key. I assume , probably incorrectly, that the ECU is reading the parameters. I have definitely heard GM cars and others starting at the first compression stroke the way carbed cars will sometimes start.
