I just bought a 2005 Land Rover Range Rover HSE with 70k miles, I have had no problems so far until, I went to a professional Car Wash, after that, I have been hearing this squeaking noise, It sounds like birds chirping... I just replaced my bushings on my control arms as they were really worn, but the sound has not gone away. I noticed that my Coil Suspension Strut mounts are a pretty worn, but Atlantic British discontinued my style with the red strut so im out of luck there :( Ball joints look good still as well
Has anyone experienced this issue?
Here is a link to the sound, it is noticeable within the car as well as outside
https://drive.google.com/open?id=1188RnUaWQUNV0b7KkYyHEE8Rg5qf53jr
Thanks in advance!
Hi,
it is probably a leak air spring. When the air leaks, you get that sound. You should check that.
Kind regards,
robert
If you are on steel springs and the supports are worn it seems like a likely culprit. Have you tried a grease spray on the supports to see if the noise changes
