ok i saw a guys post here for tjis problem and i have the same one. exactly the same thing. here is his post
"I searched the forum and the internet quite a bit to find someone that had similar problems but came up empty. It is a 1988 Range Rover with the LT230 transfer case just to be clear.
Basically the four-wheel drive isn't working correctly. If I drive it without the diff lock engaged (lower right position) it will drive for a little while and then suddenly the engine will rev up and there will be no power to the wheels. Like it slipped out of gear or something. It does that in both the low and hi range positions in (the normal un-locked diff).It won't go back into gear after putting it into neutral either, you just hear the transfer case spin.
If I engage the diff-lock (left-position) it will drive fine, but the front wheels aren't spinning. It won't pop out of gear like the normal position, but the front wheels don't seem to have any power. I tested it out in snow and on a gravel road after getting it stuck.
Here is other things I noticed:
Normal Postion ( un-locked diff) Front drive shaft is spinning, rear doesn't seem to be spinning after it "pops out of gear."
Locked Postion Front driveshaft spins, rear driveshaft spins, no power to front wheels.
I wouldn't be surprised if the previous owner drove it for with the diff-lock engaged."
Has anyone else had this happen? no idea where to start.
any ideas i really need help. ive got 2.5 ft of snow and cand pull from my drive.
