Hey guys, I just replaced and then relocated my ignition module, and my pickup coil, rotor, and ignition coil as well. Before I had no spark, now I have a weak orange spark coming off of the coil and a puff of white smoke out of the intake that smells like gas when I try to start. I assume that its possibly timing and am going to see if I installed it 180 degrees out. Anyone else know what it could be? When I relocated the ignition module I just moved it and ran wires to it, mounted it on a head sink and grounded that heat sink. I assume thats all you really need to do to relocate it right? anyway if anyone can give me some help i would like it.
Well, if you have a weak orange spark then you have a problem. The spark should be crisp and blue. You need to recheck your connections, particularly make sure the ignition amp is well earthed.
