1 - 15 of 15 Posts
My Rover was running fine, then a couple of weeks ago it died just down the street from my house. It has fuel and cranks hard, but no start.
Lucas cap and LR rotor are weeks old. I threw in a new Amplifier Module and generic coil to try to get it running - nada.
Now, the truck is moved closer to home: I have no spark at the plugs, and today found that the new coil spark seems weak - yellow, not blue. Thinking the generic coil was incompatible, I tried a new MDI Blaster 2 but, still no difference - still a rather weak spark from the coil - and nothing at the plugs.
I cleaned up all my ground wires recently - including to the coil. What or where may be keeping my spark weak?
Check the resistance through the distributor baseplate, sounds like it may be breaking down
Resistance through the baseplate should be between 2-5k. My reading was 2.88
I would check the wire to the spark modulator
And as far as the coil try going to a good junk yard look for a old jaguar they have powerful coils I use these in. My rover
I had exactly the same symptoms turned out to be the dizzy pick up. Apologies if this is what you mean by baseplate above.
Incidentally mikieman - if you don't speak English, what on earth do you speak Sir?
Watch all the episodes of I love Lucy and you can figure it out
Discussion Starter · #8 ·
The pick up is located on the base plate. I think you may be onto something. Looking back, my numbers were a little low. I find it hard to believe I've gotten two bad coils. thanks, I think I'll re-check the pick-up.
A pick over here in England is about £25.00 so not too bad. looks like a few screws and job done. I replaced my whole dizzy because the heat cap was cracked to and it was the only part of my sign system I had yet to change.
Good luck
Discussion Starter · #10 ·
Good luck
Thank you! I found one on Ebay for close to that price -- awaiting delivery - I hope today.
Good stuff I got a genuine LR one on eBay need to get it fitted I sometimes have to wiggle the wires about to get the engine running.
Hoping I can fit it in situ for laziness.....
This is very interesting. As I too have battled a bad ignition module eating new coils. This baseplate measurement.
Is this in the rave?
Where am I measuring from and to?
After removing the ignition amp module from the side of the dizzy place an ohmmeter on the two exposed male contacts of the dizzy. Should be between 2 and 5k, mine was nil!! Changed the pick up / baseplate - all good.
I had my whole dizzy off the car but I suspect you can do this insitu.
Discussion Starter · #14 ·
I appreciate all the input into this problem. Unfortunately this issue was the last straw in dealing with this old truck. Running or not, she just needed too much other work - not a confidant ride - and I decided to cut my losses and sell her...
Shame - should never really be a last straw:sad:
1 - 15 of 15 Posts
