I have an engine vibration that has gotten progressively worse. Started out as a mild rattle above 3,000 rpm now, it's more pronounced and starts at 2,500. When I take off the belt it goes away, but I'm obviously not driving, just revving the engine in my garage. The water pump is showing some play so I'll start with that, any other common vibrations coming off the belt?
Hi,
See if your viscous fan is centered, look from above and try to see the movement that the fan does. I discovered that the aftermarket viscous with poor quality tend to rotate off center... :evil: :evil: :evil: :doh:
Regards,
