Hi All,
Has anyone ever had the water leaking at the back of the L322 Vogue around the entertainment unit?The system stopped working after a heavy down pour and when i checked the area, i could see water around the unit.After cleaning around the area.It started working again.
Any quick fix or ideas to resolve this ??
Edwin.
It's a common problem. Possible entry points for water, that I know of, are:
boot seal
tow bar fittings
tailgate hinge fittings.
There's a TSB which explains what to do - although it doesn't tell you how to fix the leak only how to protect the components:
boot seal
tow bar fittings
What funny is that its inside the entertainment unit and the carpet around it is dry.I would want to know the possible entry points just within the inside on the left of the L322.
I doubt it could be tow bar or tailgate hinge because the carpet on the floor is dry.
Would you please avail this TSB which explains what to do.At the moment am just covering the amplifier and other components with plastics
Nb:i have failed to see the screenshot you have sent
I have no clue why he posted a picture instead of just posting the bulletin number.
Tech Bulletin LTB 00007v2, May 31, 2007
He did not include the actuall bulletin but it can most likely be found in existing threads or on Google.
