Hi All,
I have a 2006 L322 HSE (North American model). I am getting water ingress during rain near the right rear passenger foot-well/door sill area. From the diagrams, it doesn't look like the sunroof rear drain tubes route down the B-Pillar, so would the likely culprit be the door seal(s)?
Thanks,
Greg
Ours holds water in-between the seals somehow and you notice it draining out when the door is opened. Everything looks good but of course looks are deceiving. Nothing leaks into the cabin however. Is yours leaking into the cabin? Toad has advised re the bulletin but not sure what type of adjustment is made since our door aligns with the rest of the car as well as can be expected for this model range. At least I think it does.
