1 - 9 of 9 Posts
I'm curious if any of us later L322 owners (2010-2012) have had issues with water getting into the rear quarter electronics bay.
I poked around a little inside mine when I bought the car just for the fun of looking at all the glorious modules stuffed in there. Should I be keeping an eye on the bay for water ingress, or has this issue been resolved by 2012? Mine is bone dry and has been since I bought the car. Water in these expensive modules scares me tho.
What was/is the culprit? Bad upper tailgate seal?
I think the tailgates on Rovers are probably one of the the weak links for rust and leaks. That being said, I haven t seen any moisture in my electronics bay and I have had the whole thing disassembled a few times. I am starting to see a little rust around the weep holes on the tailgate door so I am keeping and eye on it.
2012 Range Rover HSE
Yes, this is resolved. They have the factory clear plastic splash shield installed (which was the originally factory fix for the early L322s)
I had a leak with mine. Water on the right side compartment. The vehicle had already had the left side compartment splash shield installed. I had installed factory roof rails, my assumption is that the water was coming in through the threaded mounting holes. I removed the rails and thread-sealed the holes, plus I caulked the rail holes. I never had the leak again.
Agreed thanks @sowr
Examine your splash shield closely though, mine was bunched up from the factory. I spread it out evenly behind all the components.
1 - 9 of 9 Posts
