There is quite a bit of water in there. Everything still works. Can I just drill a tiny hole to drain it until I find a replacement at a junk yard?
Don't see why not - I bought britpart clear lenses real cheap to replace cracked orange ones. Maybe cheaper than junkyard and perfectly serviceable.
sounds like a great solution ashtray - and bung in a grommet when you're done
These lenses are clear so maybe they have a drain plug. I'll check.
@romanrob I can't tell if you're being sarcastic or not :geek:. But thank you for the feedback!
They shouldn't have a drain plug as there should be nowhere for water to get in that needs to be drained out.
Okay. I'll see if I can remove it, shake the water out and just seal any crack I find with something from the autoparts store.
UPDATE: Drilled 3 tiny holes. 1 in each corner at the bottom. Water flowed out. All is well. Not in a rush to replace it. Rather spend the ~$50 bucks elsewhere. I just didn't want the water causing any electrical issues. If any issues do come up I'll update the thread and notify you guys.
lol ashtray, I was complimenting your ingenuity
