I have a small water drip that appears to be coming from the back of the tensioner arm. Does this get bolted through to an area that has coolant running through it? I see it appears to have a gasket between the block and arm assembly, so I assume that is the case.
Doing a quick search now, I can't seem to find the part name for this.
Discussion Starter #2
Ok, this may not be an issue at all. I hosed the engine bay down quite thoroughly the day before, this may just be left over water.
