Hey guys,
Been a member at discoweb for years now but picked up a 2002 range rover recently and this site/forum is awesome.
Ive almost got everything sorted out on this car. One current issues is baffling me however.
Alternator/Battery both test well. Battery is strong on test meter. Running 13.08 volts uncranked. 13.79 with acc running and engine at 2,000rpm.
Alternator has tested well also...at least per AutoZone test equipment.
The Issue:
At idle or very low RPM range when first cranking engine I get a Fuse 8 Failed on message center. This is with only radio, hvac system on. If I turn heated seats on and lights I get fuse 6,7,20 failed. These only occur sitting at idle and not when driving. Anytime I brake (come close to stop or stop) I get the beep followed by fuse 8 failed. After several miles of driving I dont get the error anymore, unless I have a lot of accessories running.
I have installed a new mass air flow sensor. Have also reset the service engine soon light. It comes back on every few days after resetting it.
Could these issues be related? I searched the forums and found mention of alternator issues corrupting MAF. Just wondering if this was normal.
Ive narrowed it down to the BECM or Alternator/battery. Replaced battery terminals and leads hoping it would help but did not.
Any experience with this kind of issue would be greatly appreciated.
Thanks in advance.
The Issue:
Thanks in advance.
