Is it possible to change the Voice Recognition ECU's language? Is it set globally from the BCM/Market Spec? So if I plug a German one in it will pick up that it's in an English car? Or does it need to be configured by the stealer?
Basically I want to add Voice Rec' and I've come across a German ECU, I've already got the steering wheel button, and will need to add the mic.
Dan
Dan
I would not bother its a rubbish system that rarely understands what you say and my English is quite BBC!
Dan
Perhaps that's the problem, Land Rover are obviously marketing the Range Rover to a different crowd, init blud.
Have you tried: "Oi ho, take me to where me homeys hang out init."
Dan_UK_1984 said:
Gazellio said:
[quote="Dan_UK_1984":1kmwi2p3]Is it possible to change the Voice Recognition ECU's language? Is it set globally from the BCM/Market Spec? So if I plug a German one in it will pick up that it's in an English car? Or does it need to be configured by the stealer?
Dan
Have you tried: "Oi ho, take me to where me homeys hang out init."[/quote:1kmwi2p3]
Yes I have - no luck either :crybaby2:
I first had voice recognition on my RRS in 2005 - never worked.
I then had it in the Discovery3 Metropolis - never worked so I took it back to Stratstones and they replaced the whole unit. Went home and it never worked either so I gave up. "Naviagation Zoom Out" ....."Command not recognised" ...."Navigation Zoom Out"...."Command not recognised"...."Navigation Zoom Out"...."Command not recognised"...."Navigation F**CK OFF" and that was that.
THen I had it in my 2005 V8 Vogue - Never worked.
And Finally my 2007 TDV8 Vogue - Most commands will not work.
It a really crap system and even a £11K new fiesta (My Mums) understands EVERY word I say or even the local take-away owner says :twisted:
