Hi pepole looking for some advice just brought me 2002 range rover vogue 3ltr diesel auto one of the kids climbed in the from and knocked the low range on seems like my transfer box doesn't work is there a way to get this working again in normal mode a precise any advice yhanks
So what exactly happens if you’re stationary with the engine running, you select Neutral on the automatic transmission with the gearshift lever, then you move the transfer box switch fully rearwards and then release it (it should return to its forward position when released)?
Does the low range indicator light on the dashboard flash? Once the shift into ‘high’ is complete, the light should stop flashing and go out, and then ‘HIGH RANGE’ should be displayed in the message centre for a few seconds.
Phil
