Ive been trying to remove my fan to install a new thermostat housing. My question is which way do i need to go to remove the bolt. Ive been tapping and turning with no luck to the left hand side. My vehicle is a 2006 range rover hse 4.4 non sport
Model jaguar engine.
JACK'S GRANDAD
There are maybe a hundred threads about radiator , water pump, and fan installs..... for which this is mentioned in every one IIRC.
Darn that pesky search thingy huh?
Martin
So i got the nut to finally break. After removing the thermostat housing do i need to apply permatex gasket to the new throttle body? Or will the new housing rubber gaskets do the job? I don’t want it to leak once putting it back together.
