My viscous coupling went bad in my blue 95 a while back and I've put off fixing it for a while now but I think I finally have time to tackle the project. I have never done a VC replacement before and there doesn't seem to be much in the shop manual about it. Does anyone know how to replace one? Thanks!
I haven't done this before, but, with a little help from google I found this:
http://www.rangerovers.net/forum/7-range-rover-mark-ii-p38/31653-viscous-coupling-replacement-how.html
Since the viscous coupling is the same between vehicles in this situation, the steps should be pretty similar
Ashcroft provides the following:
1) Remove front prop shaft
2) Drain oil from transfer box
3) Support gearbox and remove right hand gearbox mount
4) Remove bolt holding Viscous Coupling housing to transfer box
5) Rotate, to break silicone, and remove Viscous Coupling housing
6) Remove flange nut and flange and press out Viscous Coupling
7) Clean all joint faces
:cool: Replace Viscous Coupling and reassemble in reverse order
i need a new unit for mine. where is the best place to buy a new one? is it the same as the one used in the P38?
Thanks for the help y'all!
