Searched and came up with nada. So with new front end on my car the vin label shows the donor vehicle details paint code trim etc is there a numpty way to sort a proper label or is it just a case of printing something out..?
Super Moderator
Just had a look through Microcat and every label that can be fitted is listed except that one. I suspect that is because it has the VIN on it so is unique to the car. Some cars have the stuck on plastic ones, others have a proper metal one stamped with the car details. Your best bet is going to be from here http://www.vin-plate.co.uk/land_rover_plates.html, select the right one (LR1 or LR2B) and stamp the details in yourself. Alternatively, you may be able to remove the original one with hot water and a Stanley knife blade and re-use that.
