Ok, 2001 4.6 . Finally got engine running, new exhaust is great.... New issue.. Idles fine, light load almost no issue, but as i load truck ( up hill, press gas) the thing starts to vibrate, almost shudder. No lights on dash..( yey) must be mechanical.... Thoughts my brothers? U joints, tranny packing up, lost weight on prop shaft?... Has plenty of power.... For the 4.6. Nothing dripping or hanging... Help me my brothers.
The second issue is the lack of power to the washer pumps... Ill deal with that later.
Failing CPS will also present those symptoms without tossing a code.
When my front shaft ujoints went out, It started vibrating at 60 mph, also it made a strange louder muffler sound. If you put in neutral(be safe) and lay under you can double check them as long as the axles are not binding. Wiggle them and check the ujoints.
Goodluck
