2003 RR 4.4L US Version
I removed the vanos solenoid on the passenger side by unscrewing it by hand with no problem, cleaned it and replaced with a new gasket. Removed the gasket on the driver side one, but the solenoid spins but doe snot come out. An internet search on a bimmer site indicates a 32mm deep well socket is necessary to remove the drivers side. Is that correct information? Not sure why one side would require a socket and one would not, unless the passenger side one was loose. Motor has that crazy knock after an oil change and the passenger side vanos solenoid was leaking at the gasket.
Thanks,
Brian
Thanks,
Brian
