1 - 9 of 9 Posts
Hello all rangie not getting any air from the block to the tank pump is recon working and pumming air fine chanded i have air coming from exhaust port changed eas ecu still the same could this be a diver problem thanks ste.
Air coming from the exhaust port is caused by a split diaphragm, common problem and nothing to do with the ECU or driver pack.
Odd, should be fine then. I've used no end of those and never had a problem. But, if the air is coming out of the exhaust port it has got to be the diaphragm valve not sealing for whatever reason.
Hello mate just noticed when i turned the rngie off the suspension rised its self to max wadding height i put my old diaphragm back was this cause its thanks
Missing spring might have a lot to do with it. Have you changed the timer relay for a standard 4 pin one? If you do that, you need to have the car at standard height when you change the relay as it treats that as the default height.
1 - 9 of 9 Posts
