Got 2 engines in which over heated, head bolts came out way to easy so Im looking into going the stud route but nothing here in South Africa that I can find so Im going to approach a specialist company here in Johannesburg, if anyone knows of specific specs I would appreciate any info you could provide.
ie: torque settings of studs to block
torque settings of new setup vs original soec etc......
FOUNDING MEMBER
ARP makes a stud kit, not sure if you can get them there, but may be easier to import them.
I used a set last year on a customers RR and again on SWMBOd's DII, got them from www.aluminumV8.com, they came with hand-written instructions and torque specs, they insisted factory torque will rip the threads out of the block, but I don't recall the exact #...it was about 80% of factory IIRC...
Thanks for the info and will contact them regarding supplies.
Im assuming you've had no problems since.
FOUNDING MEMBER
no problems, the DII runs great, the p38 hasn't come back....
a buddy that runs a shop in Indiana swears by the ARP studs, won't do an engine or head-gasket job without them.
I used the ARP stud kit on my P38. After having done a couple of head gasket jobs using factory bolts I wouldn't go any other way now. The studs are far easier for install and to torque. THey can also be reused incase something gets fouled in the future.
Does ARP only make the one kit for all the Rover V8s ?
Steve
Thanks !
