Not to be stupid or anything, but you use MAF cleaner.frosty2008 said:how do i clean my maf?
any tips?
cheers
frosty
Here in South Africa A GEMS MAF will set you back 1200 pounds........there must be something inside them that is adding to cost.allyv8 said:If your car is Bosch equipped then in the UK its not worth doing anything but buying a new genuine one.If its Gems in the UK then its worth buying S/hand because aftermarket are total rubbish and LR want silly money.
Outside the UK I guess its down to how silly LR prices are,plus the availabilty of used stuff.
It's been covered several times. A quick use of the search button will help you out.frosty2008 said:i had gathered that bit..... :roll:
i was more wondering about technique or actual bit to clean.
