I'm preforming the audi heater core swap because my heater core is chipped and leaking through the screw. http://www.rangerovers.net/repairdetails/hevac/heatercore.html#intro
I'm at the step labeled in the link Unbolting the Lower Dash Mounts and Extracting the Heater Core
Got the two larger bolts, and I took out the smaller one on the left which goes vertically because it was circled. I removed the lower blower bolt from the frame too. I cut with tin snips where they showed but my dash is not budging at all WTF suns going down snow coming tomorrow Come on I need help!
just need to take the bottom bolt out that is facing you in the circled area. just did this myself today! I had to take a dremel and cut some of that bolt off to make it shorter. then i put a flat head screw driver behind and pryed and pulled like hell!!! took me a bit to get this done
Did you have to yank the SHHHHHHHHHHH out of it? I did. Also did you take the airbag out?
